HP 14-dq5043cl SSD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
73
All Time:
498
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your device losing your data, struggling to boot past the home screen, or loading programs very slow. If that is the case, you may have a damaged SSD. This device's storage device is known as an SSD or Solid state drive. These type of storage devices are a bit newer than their older HDD or hard drive counter parts however that usually means they are simple to work with.
The SSD or solid state drive stores all your data on your device. Ensure you have properly exported any data you find important to you as once you replace this component all the information on the original one will be inaccessible.
When ready to begin follow the steps below.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. HP 14-dq5043cl SSD Replacement, Lower Case: step 1, image 1 of 2 HP 14-dq5043cl SSD Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      Ask FixBot
    2. HP 14-dq5043cl SSD Replacement: step 2, image 1 of 1
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      Ask FixBot
    3. HP 14-dq5043cl SSD Replacement: step 3, image 1 of 3 HP 14-dq5043cl SSD Replacement: step 3, image 2 of 3 HP 14-dq5043cl SSD Replacement: step 3, image 3 of 3
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 14-dq5043cl SSD Replacement, SSD: step 4, image 1 of 2 HP 14-dq5043cl SSD Replacement, SSD: step 4, image 2 of 2
      • Remove the single screw that secures the SSD with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP 14-dq5043cl SSD Replacement: step 5, image 1 of 3 HP 14-dq5043cl SSD Replacement: step 5, image 2 of 3 HP 14-dq5043cl SSD Replacement: step 5, image 3 of 3
      • Pull the SSD directly out of its socket to remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
585 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 73
All Time: 498
