HP 14-dq5043cl Fan Replacement
    1. HP 14-dq5043cl Fan Replacement, Lower Case: step 1, image 1 of 2 HP 14-dq5043cl Fan Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      Ask FixBot
    2. HP 14-dq5043cl Fan Replacement: step 2, image 1 of 1
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      Ask FixBot
    3. HP 14-dq5043cl Fan Replacement: step 3, image 1 of 3 HP 14-dq5043cl Fan Replacement: step 3, image 2 of 3 HP 14-dq5043cl Fan Replacement: step 3, image 3 of 3
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 14-dq5043cl Fan Replacement, Fan: step 4, image 1 of 2 HP 14-dq5043cl Fan Replacement, Fan: step 4, image 2 of 2
      • Remove the three M2xL3 Phillips screws that secure the fan.
      Ask FixBot
    2. HP 14-dq5043cl Fan Replacement: step 5, image 1 of 2 HP 14-dq5043cl Fan Replacement: step 5, image 2 of 2
      • Gently disconnect the fan connector from its motherboard socket.
      • Lift the fan up and out.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
585 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 383
