HP 14-dq5009nr Battery Replacement
    1. HP 14-dq5009nr Battery Replacement, Battery: step 1, image 1 of 3 HP 14-dq5009nr Battery Replacement, Battery: step 1, image 2 of 3 HP 14-dq5009nr Battery Replacement, Battery: step 1, image 3 of 3
      • Peel the rubber feet off the bottom casing to reveal hidden screws.
      • Keep the rubber feet for reassembly.
      • Make sure the device is completely powered off before replacement.
      Ask FixBot
    2. HP 14-dq5009nr Battery Replacement: step 2, image 1 of 2 HP 14-dq5009nr Battery Replacement: step 2, image 2 of 2
      • Use a Philips #0 screwdriver to remove the eight screws from the back case.
      • Six 7 mm-long screws
      • Two 4.8 mm-long screws
      Ask FixBot
    3. HP 14-dq5009nr Battery Replacement: step 3, image 1 of 3 HP 14-dq5009nr Battery Replacement: step 3, image 2 of 3 HP 14-dq5009nr Battery Replacement: step 3, image 3 of 3
      • Use a plastic opening tool to separate the back case from the palmrest keyboard assembly. Gently pry the back cover from the device.
      • Start from a corner of the device and run the opening tool along the edge of the cover to release the clips before you separate them.
      • Be careful to not bend or crack the back cover.
      Ask FixBot
    4. HP 14-dq5009nr Battery Replacement: step 4, image 1 of 2 HP 14-dq5009nr Battery Replacement: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the battery to the chassis.
      Ask FixBot
    5. HP 14-dq5009nr Battery Replacement: step 5, image 1 of 3 HP 14-dq5009nr Battery Replacement: step 5, image 2 of 3 HP 14-dq5009nr Battery Replacement: step 5, image 3 of 3
      • Angle the battery up slightly and gently pull it from the socket on the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 46
All Time: 350
