HP 14-dq0060nr RAM Replacement
    1. HP 14-dq0060nr RAM Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over so the backside is facing up.
      • Make sure the device is shutoff and unplugged from the AC adapter. Be sure to keep track of which grip goes on which side, as one is larger than the other.
      • Use a spudger to remove the grips from the back case to reveal screws underneath.
      • Be careful when peeling the grips off so they don't tear apart. You need to reuse them them.
      Ask FixBot
    2. HP 14-dq0060nr RAM Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove six 6.0 mm screws and two 4.0 mm Phillips #1 screws.
      • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
      • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
      Ask FixBot
    3. HP 14-dq0060nr RAM Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four, 3.00 mm screws.
      Ask FixBot
    4. HP 14-dq0060nr RAM Replacement: step 4, image 1 of 1
      • Pull the battery cable away from the connector in the same direction that the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      • Remove the battery from the laptop frame.
      Ask FixBot
    1. HP 14-dq0060nr RAM Replacement, RAM Card: step 5, image 1 of 1
      • Pull the two RAM retaining arms away from the center of the RAM stick.
      • The RAM stick should "pop" up slightly from its socket.
      Ask FixBot
    2. HP 14-dq0060nr RAM Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove RAM stick.
      • To avoid bending the socket pins, remove the RAM stick at the same angle as it was released.
      Ask FixBot
Christopher Supek
217 Reputation
2 Guides authored
Gateway, Team 1-1, Pee Spring 2023 Member of Gateway, Team 1-1, Pee Spring 2023
GCC-PEE-S23S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 64
All Time: 771
