HP 14-dq0055dx RAM Replacement
    1. HP 14-dq0055dx RAM Replacement, RAM: step 1, image 1 of 3 HP 14-dq0055dx RAM Replacement, RAM: step 1, image 2 of 3 HP 14-dq0055dx RAM Replacement, RAM: step 1, image 3 of 3
      • Turn the laptop upside down exposing the screws.
      • Gently remove the rubber grips to reveal the remaining screws.
      • Using a Phillips #1 screwdriver remove all eight screws.
      Ask FixBot
    2. HP 14-dq0055dx RAM Replacement: step 2, image 1 of 1
      • Turn the laptop back over and open the screen.
      • Insert an opening tool into the seam between the keyboard and the bottom panel.
      • Run the opening tool along the seam to separate the back panel from the keyboard.
      • You may hear clicking as clips release the bottom panel from the keyboard.
      Ask FixBot
    3. HP 14-dq0055dx RAM Replacement: step 3, image 1 of 2 HP 14-dq0055dx RAM Replacement: step 3, image 2 of 2
      • After the bottom panel has been separated from the laptop, close the laptop.
      • Flip the laptop back over.
      • Carefully place hands on either side of the laptop's back panel.
      • Lift up to remove the panel.
      Ask FixBot
    4. HP 14-dq0055dx RAM Replacement: step 4, image 1 of 3 HP 14-dq0055dx RAM Replacement: step 4, image 2 of 3 HP 14-dq0055dx RAM Replacement: step 4, image 3 of 3
      • Using a Phillips #1 screwdriver remove the four 2.5 mm screws securing the battery in place.
      • Remove the battery from the laptop by gently lifting up the bottom slightly.
      • Pull the battery toward you to remove.
      • Be wary of not bending the pins when pulling the battery out.
      Ask FixBot
    5. HP 14-dq0055dx RAM Replacement: step 5, image 1 of 3 HP 14-dq0055dx RAM Replacement: step 5, image 2 of 3 HP 14-dq0055dx RAM Replacement: step 5, image 3 of 3
      • Release the metal clasps on the sides of the RAM module by gently pulling away.
      • The RAM will spring upward and remain at an angle.
      • Pull the module out at the same angle.
      • Do not touch the gold pins on the RAM module.
      Ask FixBot
Guy Medina
491 Reputation
3 Guides authored
Gateway, Team 8-88, Gonzalez Spring 2024 Member of Gateway, Team 8-88, Gonzalez Spring 2024
GCC-GONZALEZ-S24S8G88
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 81
All Time: 1,115
