HP 14-dq0052dx Power Button Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
34
Past 30 Days:
109
All Time:
677
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the power button on your HP 14-dq0052dx laptop.
Tools
    1. HP 14-dq0052dx Power Button Replacement, Back Panel: step 1, image 1 of 1
      • Orient your laptop so that the vents are facing upwards.
      Ask FixBot
    2. HP 14-dq0052dx Power Button Replacement: step 2, image 1 of 1
      • Remove the rubber feet.
      Ask FixBot
    3. HP 14-dq0052dx Power Button Replacement: step 3, image 1 of 2 HP 14-dq0052dx Power Button Replacement: step 3, image 2 of 2
      • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
      • Use an iFixit opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. HP 14-dq0052dx Power Button Replacement, Daughterboard: step 4, image 1 of 1
      • Remove the single 3 mm screw from the daughterboard using a JIS #1 screwdriver.
      Ask FixBot
    2. HP 14-dq0052dx Power Button Replacement: step 5, image 1 of 2 HP 14-dq0052dx Power Button Replacement: step 5, image 2 of 2
      • Detach the cable connector from the daughterboard using a pair of tweezers.
      • Remove the daughterboard from the laptop.
      Ask FixBot
    1. HP 14-dq0052dx Power Button Replacement, Power Button: step 6, image 1 of 1
      • Remove the power button from the laptop.
      Ask FixBot
DamianR
327 Reputation
2 Guides authored
UMass Dartmouth, Team 2-5, Konn Fall 2024 Member of UMass Dartmouth, Team 2-5, Konn Fall 2024
UMASSD-KONN-F24S2G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 109
All Time: 677
