HP 14-dq0052dx Daughterboard Replacement
    1. HP 14-dq0052dx Daughterboard Replacement, Back Panel: step 1, image 1 of 1
      • Orient your laptop so that the vents are facing upwards.
      Ask FixBot
    2. HP 14-dq0052dx Daughterboard Replacement: step 2, image 1 of 1
      • Remove the rubber feet.
      Ask FixBot
    3. HP 14-dq0052dx Daughterboard Replacement: step 3, image 1 of 2 HP 14-dq0052dx Daughterboard Replacement: step 3, image 2 of 2
      • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
      • Use an iFixit opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. HP 14-dq0052dx Daughterboard Replacement, Daughterboard: step 4, image 1 of 1
      • Remove the single 3 mm screw from the daughterboard using a JIS #1 screwdriver.
      Ask FixBot
    2. HP 14-dq0052dx Daughterboard Replacement: step 5, image 1 of 2 HP 14-dq0052dx Daughterboard Replacement: step 5, image 2 of 2
      • Detach the cable connector from the daughterboard using a pair of tweezers.
      • Remove the daughterboard from the laptop.
      Ask FixBot
Kristen Gismondi
108,488 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,118 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 477
