HP 14-dq0052dx Battery Replacement
    1. HP 14-dq0052dx Battery Replacement, Back Panel: step 1, image 1 of 1
      • Orient your laptop so that the vents are facing upwards.
      Ask FixBot
    2. HP 14-dq0052dx Battery Replacement: step 2, image 1 of 1
      • Remove the rubber feet.
      Ask FixBot
    3. HP 14-dq0052dx Battery Replacement: step 3, image 1 of 2 HP 14-dq0052dx Battery Replacement: step 3, image 2 of 2
      • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
      • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
      • Use an iFixit opening tool to pry the back cover away from the laptop.
      Ask FixBot
    1. HP 14-dq0052dx Battery Replacement, Battery: step 4, image 1 of 1
      • Unplug the battery from the motherboard.
      • Carefully pull back and raise the battery out of its slot.
      • Replace the battery.
      Ask FixBot
Jordan Graham
216 Reputation
2 Guides authored
UMass Dartmouth, Team 2-5, Konn Fall 2024 Member of UMass Dartmouth, Team 2-5, Konn Fall 2024
UMASSD-KONN-F24S2G5
4 Members
56 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 93
All Time: 1,178
