HP 14-dq0051dx Touchpad Replacement
    1. HP 14-dq0051dx Touchpad Replacement, Back Case: step 1, image 1 of 2 HP 14-dq0051dx Touchpad Replacement, Back Case: step 1, image 2 of 2
      • Turn the laptop upside down so the backside is facing up.
      • Use a Phillips #1 screwdriver to remove eight screws from the back case.
      Ask FixBot
    2. HP 14-dq0051dx Touchpad Replacement: step 2, image 1 of 1
      • Turn the laptop over and open the screen.
      • Insert the opening tool into the seam between the bottom panel and the keyboard.
      • Run the opening tool along the entire seam to separate the bottom panel.
      • You may hear clicking as you release the taps that secure the case.
      Ask FixBot
    3. HP 14-dq0051dx Touchpad Replacement: step 3, image 1 of 1
      • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
      • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
      Ask FixBot
    1. HP 14-dq0051dx Touchpad Replacement, Battery: step 4, image 1 of 3 HP 14-dq0051dx Touchpad Replacement, Battery: step 4, image 2 of 3 HP 14-dq0051dx Touchpad Replacement, Battery: step 4, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP 14-dq0051dx Touchpad Replacement, Touchpad: step 5, image 1 of 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: step 5, image 2 of 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: step 5, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the small locking flap from ZIF connector that attaches the touchpad cable to the motherboard.
      • Pull the ribbon cable out from the connector.
      • Use caution and do not yank or kink the cable, as you might damage it.
      Ask FixBot
    2. HP 14-dq0051dx Touchpad Replacement: step 6, image 1 of 3 HP 14-dq0051dx Touchpad Replacement: step 6, image 2 of 3 HP 14-dq0051dx Touchpad Replacement: step 6, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 2.0 mm screws from the metal plate covering the bottom of the touch pad.
      • Use an opening tool to remove the bottom plate.
      Ask FixBot
    3. HP 14-dq0051dx Touchpad Replacement: step 7, image 1 of 3 HP 14-dq0051dx Touchpad Replacement: step 7, image 2 of 3 HP 14-dq0051dx Touchpad Replacement: step 7, image 3 of 3
      • Lift up the flap covering to the top of the touchpad.
      • Use a Phillips #1 screwdriver to remove the three 1.5 mm screws from the top of the touchpad.
      • Use the opening tool to carefully lift up and remove the touchpad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 749
