HP 14-dq0051dx Keyboard Replacement
    1. HP 14-dq0051dx Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP 14-dq0051dx Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Turn the laptop upside down so the backside is facing up.
      • Use a Phillips #1 screwdriver to remove eight 2.5mm screws from the back case.
      Ask FixBot
    2. HP 14-dq0051dx Keyboard Replacement: step 2, image 1 of 1
      • Turn the laptop over and open the screen.
      • Insert the opening tool into the seam between the bottom panel and the keyboard.
      • Run the opening tool along the entire seam to separate the bottom panel.
      • You may hear clicking as you release the taps that secure the case.
      Ask FixBot
    3. HP 14-dq0051dx Keyboard Replacement: step 3, image 1 of 1
      • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
      • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
      Ask FixBot
    4. HP 14-dq0051dx Keyboard Replacement: step 4, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 4, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 4, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 2.5 mm screws that secure the motherboard cover.
      • Remove the motherboard cover from the laptop.
      Ask FixBot
    5. HP 14-dq0051dx Keyboard Replacement: step 5, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 5, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 5, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
      • Remove the battery from the laptop.
      Ask FixBot
    6. HP 14-dq0051dx Keyboard Replacement: step 6, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 6, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 6, image 3 of 3
      • Use the blue opening tool to flip up the small locking flap from the ZIF connector that attaches the touchpad cable to the motherboard.
      • Gently pull the ribbon cable out from the connector.
      • Ensure that the connector is pulled out gently as this is connector is very easy to damage
      Ask FixBot
    7. HP 14-dq0051dx Keyboard Replacement: step 7, image 1 of 2 HP 14-dq0051dx Keyboard Replacement: step 7, image 2 of 2
      • Gently unplug the keyboard connector from the motherboard.
      Ask FixBot
    8. HP 14-dq0051dx Keyboard Replacement: step 8, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 8, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 8, image 3 of 3
      • Lift up the small compartment with your finger.
      • Pull the flat cable out of the connector.
      Ask FixBot
    9. HP 14-dq0051dx Keyboard Replacement: step 9, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 9, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 9, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the single 1 mm screw that secure the WiFi card.
      • Pull the WiFi card out of its slot
      • Pull the WiFi card out slowly and gently as to not damage the card or the slot
      Ask FixBot
    10. HP 14-dq0051dx Keyboard Replacement: step 10, image 1 of 2 HP 14-dq0051dx Keyboard Replacement: step 10, image 2 of 2
      • Pull the charging port cable away from the connector in the same direction as the individual wires to unplug the charge port connector.
      • Remove the charging port.
      Ask FixBot
    11. HP 14-dq0051dx Keyboard Replacement: step 11, image 1 of 2 HP 14-dq0051dx Keyboard Replacement: step 11, image 2 of 2
      • Lift up the port using the blue opening tool.
      • Continue to lift up until it is unplugged from the motherboard.
      Ask FixBot
    12. HP 14-dq0051dx Keyboard Replacement: step 12, image 1 of 2 HP 14-dq0051dx Keyboard Replacement: step 12, image 2 of 2
      • Place both hands on opposite corners of the motherboard and carefully lift it up to remove it from the laptop.
      • Now the motherboard has been successfully removed and is ready to be replaced!
      Ask FixBot
    13. HP 14-dq0051dx Keyboard Replacement: step 13, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 13, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 13, image 3 of 3
      • Remove the two 2.5 mm screws that secure the motherboard cover using a Phillips #1 screwdriver.
      • Gently pull the component out of the laptop
      Ask FixBot
    14. HP 14-dq0051dx Keyboard Replacement: step 14, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 14, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 14, image 3 of 3
      • Remove the signle 2 mm screws that secure the side cover using a Phillips #0 screwdriver.
      • Pull the side cover off gently
      Ask FixBot
    15. HP 14-dq0051dx Keyboard Replacement: step 15, image 1 of 3 HP 14-dq0051dx Keyboard Replacement: step 15, image 2 of 3 HP 14-dq0051dx Keyboard Replacement: step 15, image 3 of 3
      • Remove the six 2.5 mm screws that secure the keyboard to its hinges using a Phillips #1 screwdriver.
      • Once unscrewed, pull the hinge tabs upward gently using your hands
      Ask FixBot
    16. HP 14-dq0051dx Keyboard Replacement: step 16, image 1 of 1
      • Place both hands on opposite corners of the keyboard and carefully lift it off the laptop
      Ask FixBot
Akash
646 Reputation
3 Guides authored
IUPUI, Team 2-4, Harley Fall 2023 Member of IUPUI, Team 2-4, Harley Fall 2023
IUPUI-HARLEY-F23S2G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 33
Past 30 Days: 111
All Time: 1,035
