HP 14-cf2112wm Touchpad Button Board Replacement
    1. HP 14-cf2112wm Touchpad Button Board Replacement, Back Cover: step 1, image 1 of 1
      • Before you begin, shut down your laptop and disconnect all cables.
      • Turn the laptop over so the bottom case is facing up.
      Ask FixBot
    2. HP 14-cf2112wm Touchpad Button Board Replacement: step 2, image 1 of 2 HP 14-cf2112wm Touchpad Button Board Replacement: step 2, image 2 of 2
      • Use a spudger to pry under the end of the screw cover.
      • When the edge is lifted up, use your fingers to pull the rest of the strip off.
      • Try to keep the strip intact so you can replace it at reassembly.
      Ask FixBot
    3. HP 14-cf2112wm Touchpad Button Board Replacement: step 3, image 1 of 2 HP 14-cf2112wm Touchpad Button Board Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
      Ask FixBot
    4. HP 14-cf2112wm Touchpad Button Board Replacement: step 4, image 1 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 4, image 2 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 4, image 3 of 3
      • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
      • Be careful as the case edges are sharp.
      Ask FixBot
    5. HP 14-cf2112wm Touchpad Button Board Replacement: step 5, image 1 of 1
      • Lift the back cover off the laptop.
      Ask FixBot
    1. HP 14-cf2112wm Touchpad Button Board Replacement, Battery: step 6, image 1 of 3 HP 14-cf2112wm Touchpad Button Board Replacement, Battery: step 6, image 2 of 3 HP 14-cf2112wm Touchpad Button Board Replacement, Battery: step 6, image 3 of 3
      • Place your opened laptop on a flat surface.
      • Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
      Ask FixBot
    2. HP 14-cf2112wm Touchpad Button Board Replacement: step 7, image 1 of 2 HP 14-cf2112wm Touchpad Button Board Replacement: step 7, image 2 of 2
      • Slide the battery out from the connector on the motherboard.
      Ask FixBot
    1. HP 14-cf2112wm Touchpad Button Board Replacement, Touchpad Button Board: step 8, image 1 of 2 HP 14-cf2112wm Touchpad Button Board Replacement, Touchpad Button Board: step 8, image 2 of 2
      • The touchpad button board is near the top of the case, directly under where the battery was.
      Ask FixBot
    2. HP 14-cf2112wm Touchpad Button Board Replacement: step 9, image 1 of 2 HP 14-cf2112wm Touchpad Button Board Replacement: step 9, image 2 of 2
      • Flip up the three black locking flaps.
      • Disconnect the two white ribbon cables with blue ends.
      Ask FixBot
    3. HP 14-cf2112wm Touchpad Button Board Replacement: step 10, image 1 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 10, image 2 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 10, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two black 2 mm pancake screws securing the touchpad button board.
      Ask FixBot
    4. HP 14-cf2112wm Touchpad Button Board Replacement: step 11, image 1 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 11, image 2 of 3 HP 14-cf2112wm Touchpad Button Board Replacement: step 11, image 3 of 3
      • Pull the click board upwards. Use a little force to dislodge it with your fingertips.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Kusuma-Nguyen
544 Reputation
4 Guides authored
UW Tacoma, Team E-5, Rose Fall 2025 Member of UW Tacoma, Team E-5, Rose Fall 2025
UWT-ROSE-F25SEG5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 34
All Time: 222
