HP 14-cf2112wm Battery Replacement
    1. HP 14-cf2112wm Battery Replacement, Back Cover: step 1, image 1 of 1
      • Before you begin, shut down your laptop and disconnect all cables.
      • Turn the laptop over so the bottom case is facing up.
      Ask FixBot
    2. HP 14-cf2112wm Battery Replacement: step 2, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 2, image 2 of 2
      • Use a spudger to pry under the end of the screw cover.
      • When the edge is lifted up, use your fingers to pull the rest of the strip off.
      • Try to keep the strip intact so you can replace it at reassembly.
      Ask FixBot
    3. HP 14-cf2112wm Battery Replacement: step 3, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
      Ask FixBot
    4. HP 14-cf2112wm Battery Replacement: step 4, image 1 of 3 HP 14-cf2112wm Battery Replacement: step 4, image 2 of 3 HP 14-cf2112wm Battery Replacement: step 4, image 3 of 3
      • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
      • Be careful as the case edges are sharp.
      Ask FixBot
    5. HP 14-cf2112wm Battery Replacement: step 5, image 1 of 1
      • Lift the back cover off the laptop.
      Ask FixBot
    1. HP 14-cf2112wm Battery Replacement, Battery: step 6, image 1 of 3 HP 14-cf2112wm Battery Replacement, Battery: step 6, image 2 of 3 HP 14-cf2112wm Battery Replacement, Battery: step 6, image 3 of 3
      • Place your opened laptop on a flat surface.
      • Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
      Ask FixBot
    2. HP 14-cf2112wm Battery Replacement: step 7, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 7, image 2 of 2
      • Slide the battery out from the connector on the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Shishi Hu
817 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 104
All Time: 1,671
