HP 14-an012nr Fan Replacement
    1. HP 14-an012nr Fan Replacement, Battery: step 1, image 1 of 3 HP 14-an012nr Fan Replacement, Battery: step 1, image 2 of 3 HP 14-an012nr Fan Replacement, Battery: step 1, image 3 of 3
      • Remove the battery by sliding both sliders inward.
      Ask FixBot
    1. HP 14-an012nr Fan Replacement, Back Panel: step 2, image 1 of 3 HP 14-an012nr Fan Replacement, Back Panel: step 2, image 2 of 3 HP 14-an012nr Fan Replacement, Back Panel: step 2, image 3 of 3
      • Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
      • Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
      • Remove six 4 mm screws using a Phillips #1 screwdriver.
      • Pry the back panel off using an opening tool, working your way around the edges.
      Ask FixBot
    1. HP 14-an012nr Fan Replacement, Fan: step 3, image 1 of 3 HP 14-an012nr Fan Replacement, Fan: step 3, image 2 of 3 HP 14-an012nr Fan Replacement, Fan: step 3, image 3 of 3
      • Remove the two 3 mm screws that secure the fan.
      • Gently disconnect the power cable; it can tear easily.
      • Remove the fan.
      Ask FixBot
    2. HP 14-an012nr Fan Replacement: step 4, image 1 of 2 HP 14-an012nr Fan Replacement: step 4, image 2 of 2
      • Clean the area where the fan was located with a clean soft cloth or cotton swab.
      • Once cleaned and free of dust place the new fan and follow the steps in reverse to rebuild the laptop.
      Ask FixBot
Christopher Brackeen
85 Reputation
1 Guide authored
Gateway, Team 2-2, Gonzalez Fall 2023 Member of Gateway, Team 2-2, Gonzalez Fall 2023
GCC-GONZALEZ-F23S2G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 56
All Time: 438
