HP 14-an012nr Back Panel Replacement
    1. HP 14-an012nr Back Panel Replacement, Back Panel: step 1, image 1 of 3 HP 14-an012nr Back Panel Replacement, Back Panel: step 1, image 2 of 3 HP 14-an012nr Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
      • Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
      • Remove six 4 mm screws using a Phillips #1 screwdriver.
      • Pry the back panel off using an opening tool, working your way around the edges.
      Ask FixBot
Marvin lira
303 Reputation
3 Guides authored
Gateway, Team 2-2, Gonzalez Fall 2023 Member of Gateway, Team 2-2, Gonzalez Fall 2023
GCC-GONZALEZ-F23S2G2
5 Members
60 Guides authored
1 Guide Comment
احتراق الشاشه
عباس سعد - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 62
All Time: 775
