HP 14-am052nr Keyboard Replacement
    1. HP 14-am052nr Keyboard Replacement, Battery: step 1, image 1 of 3 HP 14-am052nr Keyboard Replacement, Battery: step 1, image 2 of 3 HP 14-am052nr Keyboard Replacement, Battery: step 1, image 3 of 3
      • Turn the laptop over to its bottom so that the backside is facing you.
      • Using your fingers, push the two locking tabs inwards to release the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. HP 14-am052nr Keyboard Replacement, Back Panel: step 2, image 1 of 2 HP 14-am052nr Keyboard Replacement, Back Panel: step 2, image 2 of 2
      • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
      • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
      Ask FixBot
    2. HP 14-am052nr Keyboard Replacement: step 3, image 1 of 2 HP 14-am052nr Keyboard Replacement: step 3, image 2 of 2
      • Use a prying tool to remove the back panel from the base of the computer.
      Ask FixBot
    1. HP 14-am052nr Keyboard Replacement, Motherboard: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, remove three 3 mm screws and five 3.5 mm screws from the motherboard.
      Ask FixBot
    2. HP 14-am052nr Keyboard Replacement: step 5, image 1 of 2 HP 14-am052nr Keyboard Replacement: step 5, image 2 of 2
      • Using the Phillips #0 screwdriver, remove four 1.5 mm screws from the silver cover.
      • Remove the silver cover from the device.
      Ask FixBot
    3. HP 14-am052nr Keyboard Replacement: step 6, image 1 of 3 HP 14-am052nr Keyboard Replacement: step 6, image 2 of 3 HP 14-am052nr Keyboard Replacement: step 6, image 3 of 3
      • Unplug all connectors attached to the motherboard.
      Ask FixBot
    4. HP 14-am052nr Keyboard Replacement: step 7, image 1 of 1
      • Once all plugs and screws disconnected, remove the motherboard from the device.
      Ask FixBot
    1. HP 14-am052nr Keyboard Replacement, Keyboard: step 8, image 1 of 2 HP 14-am052nr Keyboard Replacement, Keyboard: step 8, image 2 of 2
      • Carefully pry up the metal plate and detach it from the base.
      Ask FixBot
    2. HP 14-am052nr Keyboard Replacement: step 9, image 1 of 1
      • Pull the plate away from the base while pulling the keyboard connecting cable through.
      Ask FixBot
    3. HP 14-am052nr Keyboard Replacement: step 10, image 1 of 2 HP 14-am052nr Keyboard Replacement: step 10, image 2 of 2
      • Pull the keyboard out carefully from the base.
      Ask FixBot
Corwin DeFeo
237 Reputation
1 Guide authored
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-3, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 69
All Time: 526
