HP 14-am052nr Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
60
All Time:
595
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Is your device failing to charge or failing to hold a charge? If so, the battery may be faulty and it may be time to replace it. Follow the instructions in this guide to remove and replace the battery in your HP 14-am052nr laptop.
    1. HP 14-am052nr Battery Replacement, Battery: step 1, image 1 of 3 HP 14-am052nr Battery Replacement, Battery: step 1, image 2 of 3 HP 14-am052nr Battery Replacement, Battery: step 1, image 3 of 3
      • Turn the laptop over to its bottom so that the backside is facing you.
      • Using your fingers, push the two locking tabs inwards to release the battery.
      • Remove the battery from the device.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Matthew Heather
379 Reputation
4 Guides authored
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-3, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G3
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 60
All Time: 595
