HP 10 2101 Microphone Replacement
    1. HP 10 2101 Microphone Replacement, Back Panel: step 1, image 1 of 1
      • Identify the SD card port.
      Ask FixBot
    2. HP 10 2101 Microphone Replacement: step 2, image 1 of 1
      • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
      • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
      Ask FixBot
    3. HP 10 2101 Microphone Replacement: step 3, image 1 of 1
      • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
      Ask FixBot
    4. HP 10 2101 Microphone Replacement: step 4, image 1 of 1
      • Separate the back panel from the rest of the device.
      Ask FixBot
    1. HP 10 2101 Microphone Replacement, Microphone: step 5, image 1 of 1
      • Desolder the microphone wires from the motherboard.
      Ask FixBot
    2. HP 10 2101 Microphone Replacement: step 6, image 1 of 1
      • Separate the microphone from the rest of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 441
