HP 10 2101 Battery Replacement
    1. HP 10 2101 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Identify the SD card port.
      Ask FixBot
    2. HP 10 2101 Battery Replacement: step 2, image 1 of 1
      • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
      • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
      Ask FixBot
    3. HP 10 2101 Battery Replacement: step 3, image 1 of 1
      • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
      Ask FixBot
    4. HP 10 2101 Battery Replacement: step 4, image 1 of 1
      • Separate the back panel from the rest of the device.
      Ask FixBot
    1. HP 10 2101 Battery Replacement, Battery: step 5, image 1 of 1
      • Desolder the battery connectors from the motherboard.
      Ask FixBot
    2. HP 10 2101 Battery Replacement: step 6, image 1 of 1
      • Pull the bright blue-green tabs to remove the battery from the rest of the device.
      • Pulling the tabs may not fully disconnect the battery from the metal display casing.
      Ask FixBot
    3. HP 10 2101 Battery Replacement: step 7, image 1 of 2 HP 10 2101 Battery Replacement: step 7, image 2 of 2
      • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
      • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
      Ask FixBot
3 other people completed this guide.
2 Guide Comments
Do you know where to buy a replacement battery for this device?
Nathan Wells - Reply Share
Hi Nathan,
Unfortunately HP has not released this battery for sale to the public, as seen at https://parts.hp.com/hpparts/Search_Resu.... It may be worthwhile to contact HP. Here is an email address for their customer service: ''HPparts.sales.ams@hp.com.
Bryce Harmsen - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,785
