HMDX Jam Plus Speaker Replacement
    1. HMDX Jam Plus Speaker Replacement, Battery: step 1, image 1 of 3 HMDX Jam Plus Speaker Replacement, Battery: step 1, image 2 of 3 HMDX Jam Plus Speaker Replacement, Battery: step 1, image 3 of 3
      • Flip the device over so the bottom is facing up.
      • Use the large plastic opening tool to gently pry the rubber base from the device.
      • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
      Ask FixBot
    2. HMDX Jam Plus Speaker Replacement: step 2, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
      Ask FixBot
    3. HMDX Jam Plus Speaker Replacement: step 3, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 3, image 2 of 2
      • Gently separate the base from the rest of the device to reveal the battery and the main board.
      Ask FixBot
    4. HMDX Jam Plus Speaker Replacement: step 4, image 1 of 3 HMDX Jam Plus Speaker Replacement: step 4, image 2 of 3 HMDX Jam Plus Speaker Replacement: step 4, image 3 of 3
      • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
      • Pull gently on the connectors to separate each one from the main board.
      • The battery is connected to board in the red socket and the speaker is connected in the white socket.
      Ask FixBot
    5. HMDX Jam Plus Speaker Replacement: step 5, image 1 of 3 HMDX Jam Plus Speaker Replacement: step 5, image 2 of 3 HMDX Jam Plus Speaker Replacement: step 5, image 3 of 3
      • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
      • Use the plastic opening tool to gently pry the battery free from the rest of the device.
      Ask FixBot
    6. HMDX Jam Plus Speaker Replacement: step 6, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 6, image 2 of 2
      • Use new adhesive to secure battery back to the rest of the device.
      Ask FixBot
    1. HMDX Jam Plus Speaker Replacement, Speaker: step 7, image 1 of 2 HMDX Jam Plus Speaker Replacement, Speaker: step 7, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
      Ask FixBot
    2. HMDX Jam Plus Speaker Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to pry the glue away from the wire. Be careful not to damage the wire.
      Ask FixBot
    3. HMDX Jam Plus Speaker Replacement: step 9, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to separate the center plastic piece from the rest of the device.
      • Gently lift the center plastic piece and feed the speaker wire through the hole.
      Ask FixBot
    4. HMDX Jam Plus Speaker Replacement: step 10, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 10, image 2 of 2
      • Use the plastic opening tool to separate the speaker grate from the rest of the device.
      Ask FixBot
    5. HMDX Jam Plus Speaker Replacement: step 11, image 1 of 2 HMDX Jam Plus Speaker Replacement: step 11, image 2 of 2
      • Carefully remove the speaker through the top of the device.
      • Apply new adhesive to the edge of the replacement speaker and the edge of the speaker grate to ensure they do not wiggle loose.
      Ask FixBot
Maxwell Erickson
587 Reputation
4 Guides authored
Montana Tech, Team 10-3, Shirk Fall 2015 Member of Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 1,816
