Up to 20% off select tools
HMDX Chill Front Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
81
All Time:
997
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the buttons on the HMDX Chill no longer function properly, you will need to disassemble and replace the buttons. This guide will walk you through removing the buttons from the HMDX Chill without breaking them. This guide also gives you information on how to replace new buttons easily.
    1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 3 of 3
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      Ask FixBot
    2. HMDX Chill Front Buttons Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      Ask FixBot
    3. HMDX Chill Front Buttons Replacement: step 3, image 1 of 2 HMDX Chill Front Buttons Replacement: step 3, image 2 of 2
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      Ask FixBot
    1. HMDX Chill Front Buttons Replacement, Front Buttons: step 4, image 1 of 1
      • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
      • These are located underneath the rubber base, prior to removal.
      Ask FixBot
    2. HMDX Chill Front Buttons Replacement: step 5, image 1 of 2 HMDX Chill Front Buttons Replacement: step 5, image 2 of 2
      • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
      • Push the buttons upwards, away from the base, until they come loose.
      • Use your hand to pull the linked buttons off the base.
      Ask FixBot
Author
with
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
84 Guides authored
1 Guide Comment
where can I buy new front buttons for replacement?
syanco_jim - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 81
All Time: 997
