Up to 20% off select tools
HMDX Chill Disassembly
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
79
All Time:
2,127
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your HMDX Chill is having any kind of issue this guide will show how to disassemble the device in order to begin the process of fixing your issues.
    1. HMDX Chill Disassembly, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 3 of 3
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      Ask FixBot
    2. HMDX Chill Disassembly: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      Ask FixBot
    3. HMDX Chill Disassembly: step 3, image 1 of 2 HMDX Chill Disassembly: step 3, image 2 of 2
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      Ask FixBot
Author
with
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
84 Guides authored
1 Guide Comment
I have jam zero chill. One year old. Very very little use. Maybe 3 to 4 hours total.
Plug in to charge red light comes on solid and goes out in couple of hours. Then light flashes red and zero chill will not connect.
Thank you
Lorne Janes - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 79
All Time: 2,127
