Introduction
If your HMDX Chill is no longer charging but your charging cable is functioning properly, the solution to this problem can be found through replacing the USB Charging Port. This guide will show how to disassemble the device to locate the charging port. After the HMDX Chill is disassembled, this guide will teach you how to replace the broken charging port .
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
Using a soldering tool, desolder the charging port from the motherboard.
1 Guide Comment
I have the charging port removed. Where do I find a replacement??
