HMDX Chill Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
103
All Time:
1,328
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
If the HMDX Chill begins to show issues with its ability to charge and the issue is not related to the charging port or charging cable it may be time to change the battery. This guide will show how to disassemble the device in order to locate and find the battery along with showing all of the attachments from the battery to the motherboard in order to properly replace the battery.
Tools
    1. HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Battery Replacement, Remove Rubber Base: step 1, image 3 of 3
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      Ask FixBot
    2. HMDX Chill Battery Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      Ask FixBot
    3. HMDX Chill Battery Replacement: step 3, image 1 of 2 HMDX Chill Battery Replacement: step 3, image 2 of 2
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      Ask FixBot
    1. HMDX Chill Battery Replacement, Locate the Battery: step 4, image 1 of 2 HMDX Chill Battery Replacement, Locate the Battery: step 4, image 2 of 2
      • Once the base has been removed from the rest of the speaker locate the battery.
      • It may or may not be in a wrapper.
      Ask FixBot
    2. HMDX Chill Battery Replacement, Unsolder the Battery: step 5, image 1 of 2 HMDX Chill Battery Replacement, Unsolder the Battery: step 5, image 2 of 2
      • Locate the wires that attaches from the battery to the motherboard.
      • Using a soldering iron desolder the wires from the motherboard.
      Ask FixBot
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 103
All Time: 1,328
