HMDX Chill Audio Port Replacement
    1. HMDX Chill Audio Port Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Audio Port Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Audio Port Replacement, Remove Rubber Base: step 1, image 3 of 3
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      Ask FixBot
    2. HMDX Chill Audio Port Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      Ask FixBot
    3. HMDX Chill Audio Port Replacement: step 3, image 1 of 2 HMDX Chill Audio Port Replacement: step 3, image 2 of 2
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      Ask FixBot
    1. HMDX Chill Audio Port Replacement, Motherboard: step 4, image 1 of 3 HMDX Chill Audio Port Replacement, Motherboard: step 4, image 2 of 3 HMDX Chill Audio Port Replacement, Motherboard: step 4, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
      Ask FixBot
    2. HMDX Chill Audio Port Replacement: step 5, image 1 of 1
      • Pull the motherboard away from the base gently.
      • Do not pull too hard on the motherboard. It is still attached to the base by wires.
      Ask FixBot
    3. HMDX Chill Audio Port Replacement: step 6, image 1 of 3 HMDX Chill Audio Port Replacement: step 6, image 2 of 3 HMDX Chill Audio Port Replacement: step 6, image 3 of 3
      • Use a soldering iron to desolder the wires connecting the motherboard to the case.
      Ask FixBot
    4. HMDX Chill Audio Port Replacement: step 7, image 1 of 2 HMDX Chill Audio Port Replacement: step 7, image 2 of 2
      • Insert the spudger between the case and the wire and move the spudger upwards.
      • This will cause the case to prop open.
      • The wire behind the motherboard will now be visible. Pull this out from behind.
      Ask FixBot
    5. HMDX Chill Audio Port Replacement: step 8, image 1 of 1
      • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
      Ask FixBot
    1. HMDX Chill Audio Port Replacement, Audio Jack: step 9, image 1 of 1
      • Desolder the audio jack from the motherboard using a soldering iron.
      Ask FixBot
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 643
