HMD Skyline Loudspeaker Replacement
    1. HMD Skyline Loudspeaker Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power off your phone.
      Ask FixBot
    1. HMD Skyline Loudspeaker Replacement, Separate the back cover: step 2, image 1 of 3 HMD Skyline Loudspeaker Replacement, Separate the back cover: step 2, image 2 of 3 HMD Skyline Loudspeaker Replacement, Separate the back cover: step 2, image 3 of 3
      • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
      • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
      Ask FixBot
    2. HMD Skyline Loudspeaker Replacement: step 3, image 1 of 3 HMD Skyline Loudspeaker Replacement: step 3, image 2 of 3 HMD Skyline Loudspeaker Replacement: step 3, image 3 of 3
      • Before separating the back cover, note the following:
      • There's a seam just under the back cover panel. Don't insert your tool here.
      • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
      • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
      • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
      Ask FixBot
    3. HMD Skyline Loudspeaker Replacement: step 4, image 1 of 3 HMD Skyline Loudspeaker Replacement: step 4, image 2 of 3 HMD Skyline Loudspeaker Replacement: step 4, image 3 of 3
      • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
      Ask FixBot
    4. HMD Skyline Loudspeaker Replacement, Remove the back cover: step 5, image 1 of 3 HMD Skyline Loudspeaker Replacement, Remove the back cover: step 5, image 2 of 3 HMD Skyline Loudspeaker Replacement, Remove the back cover: step 5, image 3 of 3
      • Lift and remove the back cover.
      • During reassembly:
      • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
      • If you're installing a new back cover:
      • Make sure you remove all liners from the underside.
      • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
      • Rotate the bottom screw clockwise to ensure a proper fit.
      • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
      Ask FixBot
    1. HMD Skyline Loudspeaker Replacement, Disconnect the battery: step 6, image 1 of 2 HMD Skyline Loudspeaker Replacement, Disconnect the battery: step 6, image 2 of 2
      • Use a T3 Torx screwdriver to remove the two screws securing the battery connector cover.
      Ask FixBot
    2. HMD Skyline Loudspeaker Replacement: step 7, image 1 of 2 HMD Skyline Loudspeaker Replacement: step 7, image 2 of 2
      • Gently flip the graphite sheet on the battery over the top edge of your phone.
      • Be careful not to tear the sheet, as it's very delicate.
      Ask FixBot
    3. HMD Skyline Loudspeaker Replacement: step 8, image 1 of 3 HMD Skyline Loudspeaker Replacement: step 8, image 2 of 3 HMD Skyline Loudspeaker Replacement: step 8, image 3 of 3
      • Insert the point of a spudger in the notch on the left edge of the battery connector cover and pry up to release its clips.
      • Only insert your tool enough to pry up the cover. Otherwise, you may accidentally disconnect the rear camera press connector.
      • Remove the cover.
      • During reassembly, firmly press the cover into place to engage the clips.
      Ask FixBot
    4. HMD Skyline Loudspeaker Replacement: step 9, image 1 of 3 HMD Skyline Loudspeaker Replacement: step 9, image 2 of 3 HMD Skyline Loudspeaker Replacement: step 9, image 3 of 3
      • Insert the tip of an opening pick under the top edge of the battery press connector and pry up to disconnect it.
      • Check if the rear camera press connector got disconnected during the previous step. If it did, reconnect it.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
      Ask FixBot
    1. HMD Skyline Loudspeaker Replacement, Remove the loudspeaker: step 10, image 1 of 2 HMD Skyline Loudspeaker Replacement, Remove the loudspeaker: step 10, image 2 of 2
      • Use a T3 Torx screwdriver to remove the seven screws securing the loudspeaker:
      • Four 3.9 mm‑long screws
      • Three 4.9 mm‑long screws
      Ask FixBot
    2. HMD Skyline Loudspeaker Replacement: step 11, image 1 of 3 HMD Skyline Loudspeaker Replacement: step 11, image 2 of 3 HMD Skyline Loudspeaker Replacement: step 11, image 3 of 3
      • Insert the tip of a spudger under the center of the loudspeaker's top edge and lift to release its clips.
      • Don't pry against the battery, and be very careful not to puncture it with your tool.
      Ask FixBot
    3. HMD Skyline Loudspeaker Replacement: step 12, image 1 of 2 HMD Skyline Loudspeaker Replacement: step 12, image 2 of 2
      • Remove the loudspeaker.
      • During reassembly, lay the loudspeaker in place and press firmly around its perimeter to engage the clips.
      Ask FixBot
2 other people completed this guide.
Spencer Day
206,465 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,871 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 80
All Time: 1,214
