Up to 20% off select tools
HMD Skyline Back Cover Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
144
All Time:
4,564
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a cracked or damaged back cover on your HMD Skyline smartphone.
The back cover includes the wireless charging coil. If your phone's wireless charging is intermittent or not charging at all, you may need to replace the back cover.
    1. HMD Skyline Back Cover Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power off your phone.
      Ask FixBot
    1. HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 1 of 3 HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 2 of 3 HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 3 of 3
      • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
      • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
      Ask FixBot
    2. HMD Skyline Back Cover Replacement: step 3, image 1 of 3 HMD Skyline Back Cover Replacement: step 3, image 2 of 3 HMD Skyline Back Cover Replacement: step 3, image 3 of 3
      • Before separating the back cover, note the following:
      • There's a seam just under the back cover panel. Don't insert your tool here.
      • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
      • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
      • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
      Ask FixBot
    3. HMD Skyline Back Cover Replacement: step 4, image 1 of 3 HMD Skyline Back Cover Replacement: step 4, image 2 of 3 HMD Skyline Back Cover Replacement: step 4, image 3 of 3
      • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
      Ask FixBot
    4. HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 1 of 3 HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 2 of 3 HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 3 of 3
      • Lift and remove the back cover.
      • During reassembly:
      • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
      • If you're installing a new back cover:
      • Make sure you remove all liners from the underside.
      • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
      • Rotate the bottom screw clockwise to ensure a proper fit.
      • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
      Ask FixBot
3 other people completed this guide.
Author
with
Spencer Day
210,904 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Hello, how can I order a back cover to Russia?
Gleb Andrusishin - Reply Share
So easy to replace my broken back cover that I finished and was like "that's it?"
Dustin Metzgar - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 144
All Time: 4,564
