Up to 20% off select tools
HMD Barbie Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
96
All Time:
434
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your HMD Barbie Phone's (model number TA-1420) screen does not turn on, but phone audio can be heard, a damaged screen is a likely cause of the malfunction. This device is a flip phone, so the screen is not a separate part but part of the device housing so, if you wish to replace the screen, you will need to find a matching device housing.
Before beginning this guide, check out this troubleshooting page to rule out any other causes of screen malfunctions for the Barbie Phone:
HMD Barbie Phone Screen Not Turning On
Before starting this guide, make sure to fully power off your Barbie Phone. Follow the steps in this guide to replace the screen on your Barbie Phone.
    1. HMD Barbie Screen Replacement, Battery: step 1, image 1 of 3 HMD Barbie Screen Replacement, Battery: step 1, image 2 of 3 HMD Barbie Screen Replacement, Battery: step 1, image 3 of 3
      • Fully power off the phone.
      • Remove the backplate by gripping it around the edges and pulling away from the phone.
      Ask FixBot
    2. HMD Barbie Screen Replacement: step 2, image 1 of 3 HMD Barbie Screen Replacement: step 2, image 2 of 3 HMD Barbie Screen Replacement: step 2, image 3 of 3
      • Grip the battery from the top and pull away from the phone.
      • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
      Ask FixBot
    1. HMD Barbie Screen Replacement, Inner Backplate: step 3, image 1 of 1
      • Remove the six 5mm screws using the T5 Torx screwdriver.
      Ask FixBot
    2. HMD Barbie Screen Replacement: step 4, image 1 of 2 HMD Barbie Screen Replacement: step 4, image 2 of 2
      • Remove the backplate using an opening tool.
      • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
      Ask FixBot
    1. HMD Barbie Screen Replacement, Motherboard: step 5, image 1 of 3 HMD Barbie Screen Replacement, Motherboard: step 5, image 2 of 3 HMD Barbie Screen Replacement, Motherboard: step 5, image 3 of 3
      • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
      Ask FixBot
    2. HMD Barbie Screen Replacement: step 6, image 1 of 3 HMD Barbie Screen Replacement: step 6, image 2 of 3 HMD Barbie Screen Replacement: step 6, image 3 of 3
      • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
      • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
      • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
      • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
      Ask FixBot
    3. HMD Barbie Screen Replacement: step 7, image 1 of 3 HMD Barbie Screen Replacement: step 7, image 2 of 3 HMD Barbie Screen Replacement: step 7, image 3 of 3
      • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
      • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
      Ask FixBot
    1. HMD Barbie Screen Replacement, Keypad: step 8, image 1 of 3 HMD Barbie Screen Replacement, Keypad: step 8, image 2 of 3 HMD Barbie Screen Replacement, Keypad: step 8, image 3 of 3
      • Push the keypad out of the outer casing from the front of the phone, outward.
      • You may now replace the keypad with a new one, inserting it where the old keypad was. Make sure to not obstruct any of the holes for screws with the keypad.
      Ask FixBot
    1. HMD Barbie Screen Replacement, Screen: step 9, image 1 of 1
      • Remove all removable components from the device housing: the battery, inner backplate, motherboard, and keypad.
      • As this device is a flip phone, the screen is part of the device housing, so you will need to transfer the inner parts to a new device housing in order to replace the screen.
      Ask FixBot
Author
with
Hannah Carvalho
571 Reputation
5 Guides authored
1 Guide Comment
My daughter broke the mirror of her Barbie Phone. I ordered a new one but I don't know how to replace it. Can you please help me? Pictures would be so helpful ;)
Minke - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 96
All Time: 434
