HMD Barbie Motherboard Replacement
    1. HMD Barbie Motherboard Replacement, Battery: step 1, image 1 of 3 HMD Barbie Motherboard Replacement, Battery: step 1, image 2 of 3 HMD Barbie Motherboard Replacement, Battery: step 1, image 3 of 3
      • Fully power off the phone.
      • Remove the backplate by gripping it around the edges and pulling away from the phone.
      Ask FixBot
    2. HMD Barbie Motherboard Replacement: step 2, image 1 of 3 HMD Barbie Motherboard Replacement: step 2, image 2 of 3 HMD Barbie Motherboard Replacement: step 2, image 3 of 3
      • Grip the battery from the top and pull away from the phone.
      • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
      Ask FixBot
    1. HMD Barbie Motherboard Replacement, Inner Backplate: step 3, image 1 of 1
      • Remove the six 5mm screws using the T5 Torx screwdriver.
      Ask FixBot
    2. HMD Barbie Motherboard Replacement: step 4, image 1 of 2 HMD Barbie Motherboard Replacement: step 4, image 2 of 2
      • Remove the backplate using an opening tool.
      • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
      Ask FixBot
    1. HMD Barbie Motherboard Replacement, Motherboard: step 5, image 1 of 3 HMD Barbie Motherboard Replacement, Motherboard: step 5, image 2 of 3 HMD Barbie Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
      Ask FixBot
    2. HMD Barbie Motherboard Replacement: step 6, image 1 of 3 HMD Barbie Motherboard Replacement: step 6, image 2 of 3 HMD Barbie Motherboard Replacement: step 6, image 3 of 3
      • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
      • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
      • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
      • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
      Ask FixBot
    3. HMD Barbie Motherboard Replacement: step 7, image 1 of 3 HMD Barbie Motherboard Replacement: step 7, image 2 of 3 HMD Barbie Motherboard Replacement: step 7, image 3 of 3
      • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
      • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
      Ask FixBot
Hannah Carvalho
571 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 66
All Time: 231
