Introduction
Go to step 1 ↓If your HMD Barbie Phone (model number TA-1420) is not holding a charge or is not turning on, you may need to replace the battery. The battery in this device is easily removed and replaced if necessary, but if you find swelling or other physical damage of the battery, take proper precautions.
Check out this troubleshooting page to rule out other causes of the Barbie Phone not turning on:
HMD Barbie Phone Screen Not Turning On
Before beginning this guide, ensure the Barbie Phone is fully powered off. Follow the steps in this guide to remove the battery.
Fully power off the phone.
Remove the backplate by gripping it around the edges and pulling away from the phone.
