Up to 20% off select tools
HKC P776A Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
96
All Time:
1,187
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HKC P776A Battery Replacement, Separating Digitizer and Case: step 1, image 1 of 1
      • Insert the plastic opening tool between the digitizer and the case.
      • Place the spudger in the gap created by the plastic opening tool to assist in separation.
      Ask FixBot
    2. HKC P776A Battery Replacement: step 2, image 1 of 2 HKC P776A Battery Replacement: step 2, image 2 of 2
      • Slide the spudger along the perimeter of the device to fully separate the two pieces.
      Ask FixBot
    1. HKC P776A Battery Replacement, Battery: step 3, image 1 of 1
      • Insert the plastic opening tool between the battery and case.
      • Apply leverage to break the glue that is attaching the battery to the case.
      Ask FixBot
    2. HKC P776A Battery Replacement: step 4, image 1 of 1
      • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
      • Breaking all the glue between the battery and case may take a long time.
      Ask FixBot
    3. HKC P776A Battery Replacement: step 5, image 1 of 2 HKC P776A Battery Replacement: step 5, image 2 of 2
      • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
      • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
      Ask FixBot
    4. HKC P776A Battery Replacement: step 6, image 1 of 1
      • Suck up the leftover solder using the desoldering pump.
      • Remove the battery from the motherboard.
      Ask FixBot
Author
with
Ryan Gornati
409 Reputation
4 Guides authored
USF Tampa, Team 7-6, Remmell Winter 2015 Member of USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 96
All Time: 1,187
