HKC P774A LCD screen Replacement
    1. HKC P774A LCD screen Replacement, Digitizer: step 1, image 1 of 3 HKC P774A LCD screen Replacement, Digitizer: step 1, image 2 of 3 HKC P774A LCD screen Replacement, Digitizer: step 1, image 3 of 3
      • Insert the flat end of the spudger into the side of the device
      • This will create a gap between the device and screen housing.
      • Insert the plastic opening tool into this gap and move it along this gap.
      • Make sure not to bent the digitizer during this step.
      • The screen housing and device will now be separated.
      Ask FixBot
    2. HKC P774A LCD screen Replacement: step 2, image 1 of 3 HKC P774A LCD screen Replacement: step 2, image 2 of 3 HKC P774A LCD screen Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
      • Two small black pins (circled in red) will need to be unlocked.
      • Unlock the pins by pulling them outward with the tweezers.
      • Make sure the pins are released entirely before attempting to remove the band.
      • Remove the band using the tweezers.
      Ask FixBot
    3. HKC P774A LCD screen Replacement: step 3, image 1 of 3 HKC P774A LCD screen Replacement: step 3, image 2 of 3 HKC P774A LCD screen Replacement: step 3, image 3 of 3
      • Once the digitizer has been disconnected from the motherboard, the LCD screen must be removed from the digitizer.
      • Push open the tabs (circled in red) using the flat end of the plastic spudger.
      • Be sure not to bend the digitizer while prying.
      • Continue to release all tabs while continuing to pry the LCD away from the digitizer.
      Ask FixBot
    1. HKC P774A LCD screen Replacement, LCD screen: step 4, image 1 of 3 HKC P774A LCD screen Replacement, LCD screen: step 4, image 2 of 3 HKC P774A LCD screen Replacement, LCD screen: step 4, image 3 of 3
      Buy
      • Once the digitizer has been removed, the LCD can be disconnected from the motherboard.
      • Use the tweezers to unlock the black pins (outlined in red) that connect the LCD band to the motherboard.
      • Once the pins have been removed, pull the band out using the tweezers.
      • Make sure not to damage the band when removing the pins.
      Ask FixBot
Sean McCauley
512 Reputation
4 Guides authored
Montana Tech, Team 10-1, Shirk Fall 2015 Member of Montana Tech, Team 10-1, Shirk Fall 2015
MTUM-SHIRK-F15S10G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 652
