Introduction
Go to step 1 ↓The guide will show you how to replace the battery on the HKC p774A tablet. This is a difficult process, and the battery will need to be properly disposed of upon completion.
Insert the flat end of the spudger into the side of the device
This will create a gap between the device and screen housing.
Insert the plastic opening tool into this gap and move it along this gap.
The screen housing and device will now be separated.
Tool used on this step:Tweezers$4.99
Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
Two small black pins (circled in red) will need to be unlocked.
Unlock the pins by pulling them outward with the tweezers.
Remove the band using the tweezers.
Use the tweezers to pull out the black pins (circled in red).
Use the tweezers to remove the camera band from the motherboard.
