Up to 20% off select tools
HKC P771A Digitizer Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
78
All Time:
783
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HKC P771A Digitizer Replacement, Digitizer: step 1, image 1 of 2 HKC P771A Digitizer Replacement, Digitizer: step 1, image 2 of 2
      • Remove back of tablet using the plastic opening tool
      • Slide the opening tool between the back of the tablet and the digitizer
      • Lift along the edges until the back of the tablet and the digitizer are separated
      Ask FixBot
    2. HKC P771A Digitizer Replacement: step 2, image 1 of 2 HKC P771A Digitizer Replacement: step 2, image 2 of 2
      • Remove 4 screws located on the red motherboard
      • The red motherboard will be loose, but does not need to come completely unattached
      Ask FixBot
    3. HKC P771A Digitizer Replacement: step 3, image 1 of 1
      • Remove 7 screws located around the edges of the tablet
      • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
      Ask FixBot
    4. HKC P771A Digitizer Replacement: step 4, image 1 of 1
      • Lift digitizer from the screen
      • After removing all of the screws, the screen should easily separate from the digitizer
      Ask FixBot
    5. HKC P771A Digitizer Replacement: step 5, image 1 of 1
      • Now you can replace the old digitizer with a new one
      Ask FixBot
Author
with
Sara Hill
101 Reputation
2 Guides authored
Ohio State, Team 2-3, Garvin Fall 2015 Member of Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 78
All Time: 783
