Up to 20% off select tools
HKC P771A Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
75
All Time:
623
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HKC P771A Camera Replacement, Camera: step 1, image 1 of 3 HKC P771A Camera Replacement, Camera: step 1, image 2 of 3 HKC P771A Camera Replacement, Camera: step 1, image 3 of 3
      • Remove back of tablet using the plastic opening tool
      • Slide the opening tool between the back of the tablet and the digitizer
      • Lift along the edges until the back of the tablet and the digitizer are separated
      Ask FixBot
    2. HKC P771A Camera Replacement: step 2, image 1 of 2 HKC P771A Camera Replacement: step 2, image 2 of 2
      • Remove yellow tape around the edges of the battery
      • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
      Ask FixBot
    3. HKC P771A Camera Replacement: step 3, image 1 of 3 HKC P771A Camera Replacement: step 3, image 2 of 3 HKC P771A Camera Replacement: step 3, image 3 of 3
      • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
      Ask FixBot
    4. HKC P771A Camera Replacement: step 4, image 1 of 1
      • Remove yellow tape that is securing the camera wires
      Ask FixBot
    5. HKC P771A Camera Replacement: step 5, image 1 of 2 HKC P771A Camera Replacement: step 5, image 2 of 2
      • Remove silver foil from the back of the camera using the blue opening tool
      Ask FixBot
    6. HKC P771A Camera Replacement: step 6, image 1 of 1
      • Lift the bronze, L-shaped ribbon
      • The camera is attached to the end of this ribbon so it will move with it
      Ask FixBot
    7. HKC P771A Camera Replacement: step 7, image 1 of 1
      • Flip up the black bar located on the motherboard
      • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
      Ask FixBot
    8. HKC P771A Camera Replacement: step 8, image 1 of 1
      • Remove the bronze, L-shaped ribbon from inside the black bar
      Ask FixBot
    9. HKC P771A Camera Replacement: step 9, image 1 of 1
      • Your camera is now removed from the tablet
      Ask FixBot
Author
with
Sara Hill
101 Reputation
2 Guides authored
Ohio State, Team 2-3, Garvin Fall 2015 Member of Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 75
All Time: 623
