HAMILTON C-1 Battery Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. HAMILTON C-1 Battery Replacement, Battery: step 1, image 1 of 1
      • Orient the Hamilton-C1 monitor so the front view is facing you.
      • Pry open the battery cover flap located at number 10 of the graphic.
      Ask FixBot
    2. HAMILTON C-1 Battery Replacement: step 2, image 1 of 1
      • Fully insert the battery into the slot.
      Ask FixBot
    3. HAMILTON C-1 Battery Replacement: step 3, image 1 of 1
      • Use your Flathead 4 mm Screwdriver to attach the battery cover with two captive screws.
      Ask FixBot
Tina Vo
538 Reputation
4 Guides authored
Cal Poly, Team S7-G11, Paton Spring 2020 Member of Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Members
72 Guides authored
1 Guide Comment
Quelle est la différence entre la batterie interne et la batterie1
service maintenance - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 59
All Time: 2,421
