GuliKit Elves 2 Pro NS59 Controller Buttons Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
78
All Time:
220
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows you how to replace the colored buttons on the right-hand side of your Guilkit Elves 2 Pro controller. Make sure to power off the controller before beginning.
The procedure is difficult and requires a full disassembly of the controller to reach the buttons. The tool requirements are minimal, and the process is expected to take at most half an hour.
Tools
    1. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Joystick Thumb Caps: step 1, image 1 of 3 GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Joystick Thumb Caps: step 1, image 2 of 3 GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Joystick Thumb Caps: step 1, image 3 of 3
      • Use your fingers or a pair of tweezers to grip and pop off the thumb caps from the front of the controller.
      • The red syncing indicator must be off.
      Ask FixBot
    1. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Battery: step 2, image 1 of 1
      • Flip the controller on its back.
      • Remove the six 11 mm screws from the back cover of the controller using a Phillips #0 screwdriver.
      • Use a plastic pick if the back cover refuses to pry open.
      Ask FixBot
    2. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 3, image 1 of 1
      • Detach the two connectors from the vibrators and the connector from the battery using a pair of tweezers.
      • Refrain pulling the connector by the cable.
      Ask FixBot
    3. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 4, image 1 of 2 GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 4, image 2 of 2
      • Slide the shoulder trigger piece out.
      Ask FixBot
    4. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 5, image 1 of 1
      • Detach the ribbon cable using tweezers.
      • Pull by the ribbon cable and avoid pulling by the head.
      Ask FixBot
    5. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 6, image 1 of 1
      • Remove the three 11 mm screws from the D-pad cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 7, image 1 of 1
      • Remove the seven 7.8 mm screws from the motherboard using a Phillips #0 screwdriver.
      Ask FixBot
    7. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 8, image 1 of 1
      • Use a heat gun to soften the adhesive tape on battery.
      • Pry the battery out using a plastic pick.
      Ask FixBot
    1. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Motherboard: step 9, image 1 of 2 GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Motherboard: step 9, image 2 of 2
      • Use a plastic pick to pry out the motherboard.
      Ask FixBot
    1. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement, Controller Buttons: step 10, image 1 of 1
      • Remove the rubber cover for the buttons; tweezers are optional but recommended.
      Ask FixBot
    2. GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 11, image 1 of 2 GuliKit Elves 2 Pro NS59 Controller Buttons Replacement: step 11, image 2 of 2
      • Remove the buttons by pushing them in from the front of the controller.
      Ask FixBot
Youssef Bouaziz
383 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 78
All Time: 220
