GuliKit Elves 2 Pro NS59 Battery Replacement
    1. GuliKit Elves 2 Pro NS59 Battery Replacement, Joystick Thumb Caps: step 1, image 1 of 3 GuliKit Elves 2 Pro NS59 Battery Replacement, Joystick Thumb Caps: step 1, image 2 of 3 GuliKit Elves 2 Pro NS59 Battery Replacement, Joystick Thumb Caps: step 1, image 3 of 3
      • Use your fingers or a pair of tweezers to grip and pop off the thumb caps from the front of the controller.
      • The red syncing indicator must be off.
      Ask FixBot
    1. GuliKit Elves 2 Pro NS59 Battery Replacement, Battery: step 2, image 1 of 1
      • Flip the controller on its back.
      • Remove the six 11 mm screws from the back cover of the controller using a Phillips #0 screwdriver.
      • Use a plastic pick if the back cover refuses to pry open.
      Ask FixBot
    2. GuliKit Elves 2 Pro NS59 Battery Replacement: step 3, image 1 of 1
      • Detach the two connectors from the vibrators and the connector from the battery using a pair of tweezers.
      • Refrain pulling the connector by the cable.
      Ask FixBot
    3. GuliKit Elves 2 Pro NS59 Battery Replacement: step 4, image 1 of 2 GuliKit Elves 2 Pro NS59 Battery Replacement: step 4, image 2 of 2
      • Slide the shoulder trigger piece out.
      Ask FixBot
    4. GuliKit Elves 2 Pro NS59 Battery Replacement: step 5, image 1 of 1
      • Detach the ribbon cable using tweezers.
      • Pull by the ribbon cable and avoid pulling by the head.
      Ask FixBot
    5. GuliKit Elves 2 Pro NS59 Battery Replacement: step 6, image 1 of 1
      • Remove the three 11 mm screws from the D-pad cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. GuliKit Elves 2 Pro NS59 Battery Replacement: step 7, image 1 of 1
      • Remove the seven 7.8 mm screws from the motherboard using a Phillips #0 screwdriver.
      Ask FixBot
    7. GuliKit Elves 2 Pro NS59 Battery Replacement: step 8, image 1 of 1
      • Use a heat gun to soften the adhesive tape on battery.
      • Pry the battery out using a plastic pick.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 56
