Tools
Introduction
Go to step 1 ↓If the fork arm in The Buttonholer is not moving properly while being operated, chance are you need to replace the spring holding the arm.
Unscrew the screw located underneath fork arm using a Flathead screwdriver.
Raise the fork arm so that it is parallel with the upper hook.
Turn the lower hook towards you from the bottom, and remove.
