GravityLight Mounting Post Replacement and Spring Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
103
All Time:
1,256
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
To remove the mounting post, you must take out all internal parts in front of the mounting post. Push down on the spring that is holding the mounting post in place. When the spring is compressed, both the mounting post and the spring can be removed if you push them away from the outside casing.
Tools
    1. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: step 1, image 1 of 2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: step 1, image 2 of 2
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
      Ask FixBot
    2. GravityLight Mounting Post Replacement and Spring Replacement, Opening the Device Housing: step 2, image 1 of 1
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
      Ask FixBot
    1. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Back Panel Screws: step 3, image 1 of 1
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
      Ask FixBot
    2. GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: step 4, image 1 of 3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: step 4, image 2 of 3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: step 4, image 3 of 3
      • Firmly grasp both parts of the back panel and pull them apart.
      Ask FixBot
    1. GravityLight Mounting Post Replacement and Spring Replacement, Orienting the Middle Section: step 5, image 1 of 1
      • Place the middle section on a sturdy surface.
      • Move any wires in front of the mounting post.
      Ask FixBot
    2. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: step 6, image 1 of 2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: step 6, image 2 of 2
      • Push down on the spring.
      • The spring is very stiff. Compressing the spring requires a moderate amount of force.
      • Push the spring and the mounting post away from the middle section and remove them from the pocket.
      Ask FixBot
    3. GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: step 7, image 1 of 2 GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: step 7, image 2 of 2
      • Pull the mounting post out of the inside of the spring
      Ask FixBot
Jamie Forslin
143 Reputation
1 Guide authored
Cal Poly, Team 12-2, Forte Fall 2014 Member of Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 103
All Time: 1,256
