Up to 20% off select tools
GravityLight Internal Gears Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
114
All Time:
3,848
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If the bag of rocks is not moving due to an internal issue, it might be because the gears are stripped! You will learn how to replace them.
    1. GravityLight Internal Gears Replacement, Removing the Front Panel: step 1, image 1 of 2 GravityLight Internal Gears Replacement, Removing the Front Panel: step 1, image 2 of 2
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
      Ask FixBot
    2. GravityLight Internal Gears Replacement, Opening the Device Housing: step 2, image 1 of 1
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
      Ask FixBot
    1. GravityLight Internal Gears Replacement, Isolating the Back Panel: step 3, image 1 of 1
      • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
      Ask FixBot
    2. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: step 4, image 1 of 1
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
      Ask FixBot
    3. GravityLight Internal Gears Replacement, Removing the LED Housing: step 5, image 1 of 1
      • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
      • Gently lift off the LED housing (the white disk).
      • Set the LED housing on the table next to the body of the device.
      Ask FixBot
    4. GravityLight Internal Gears Replacement, Removing White Frame and Gear: step 6, image 1 of 1
      • Lift off the white piece with four arms.
      • Lift off the black-rimmed gear.
      • Set both pieces aside in a safe place.
      Ask FixBot
    5. GravityLight Internal Gears Replacement, Removing Internal Gears: step 7, image 1 of 2 GravityLight Internal Gears Replacement, Removing Internal Gears: step 7, image 2 of 2
      • Lift off the three 3.5cm diameter gears.
      • Replace any stripped gears.
      Ask FixBot
Author
with
Michallynn Hoffman
317 Reputation
3 Guides authored
Cal Poly, Team 12-2, Forte Fall 2014 Member of Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Members
84 Guides authored
1 Guide Comment
Where can we find the replacement gears?
fb - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 114
All Time: 3,848
