Graco Secure Coverage Vibrator Replacement on Parent Unit
    1. Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: step 1, image 1 of 3 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: step 1, image 2 of 3 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: step 1, image 3 of 3
      • Using plastic opening tool, pry and remove the battery lid.
      Ask FixBot
    2. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 2, image 1 of 1
      • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
      • Make sure that you disconnect the battery's wire before you remove the battery.
      Ask FixBot
    1. Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Vibrator: step 3, image 1 of 2 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Vibrator: step 3, image 2 of 2
      • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
      Ask FixBot
    2. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 4, image 1 of 2 Graco Secure Coverage Vibrator Replacement on Parent Unit: step 4, image 2 of 2
      • Using opening plastic tool, pry the two grey cases from both sides of the device.
      • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
      • While pry off the grey cases, hold the device with your other hand to remove the cases.
      Ask FixBot
    3. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 5, image 1 of 1
      • Pry the edges of the device to separate the front case away from the rare case.
      • While prying the edges, hold the device with one hand to pull out each case a part.
      • Make sure you use a constant force, and the pushbuttons are pried off completely.
      Ask FixBot
    4. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 6, image 1 of 2 Graco Secure Coverage Vibrator Replacement on Parent Unit: step 6, image 2 of 2
      • Remove the 7mm Phillips #1 screw from the mother board.
      • Place the screw in a secure place.
      Ask FixBot
    5. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 7, image 1 of 1
      • Pick up the motherboard carefully.
      • Using plastic opening tool, pry and remove the vibrator part.
      Ask FixBot
    6. Graco Secure Coverage Vibrator Replacement on Parent Unit: step 8, image 1 of 1
      • Solder off vibrator from the motherboard.
      • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the vibrator wires.
      • Replace the vibrator.
      Ask FixBot
Ahmed Elshaer
201 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 817
