Up to 20% off select tools
Graco Secure Coverage Parent Unit Power Jack Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
99
All Time:
759
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the power jack on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The power jack replacement includes the power jack and battery replacement.
    1. Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: step 1, image 1 of 3 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: step 1, image 2 of 3 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: step 1, image 3 of 3
      • Using plastic opening tool, pry and remove the battery lid.
      Ask FixBot
    2. Graco Secure Coverage Parent Unit Power Jack Replacement: step 2, image 1 of 1
      • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
      • Make sure that you disconnect the battery's wire before you remove the battery.
      Ask FixBot
    1. Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Power Jack: step 3, image 1 of 2 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Power Jack: step 3, image 2 of 2
      • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
      Ask FixBot
    2. Graco Secure Coverage Parent Unit Power Jack Replacement: step 4, image 1 of 2 Graco Secure Coverage Parent Unit Power Jack Replacement: step 4, image 2 of 2
      • Using opening plastic tool, pry the two grey cases from both sides of the device.
      • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
      • While pry off the grey cases, hold the device with your other hand to remove the cases.
      Ask FixBot
    3. Graco Secure Coverage Parent Unit Power Jack Replacement: step 5, image 1 of 1
      • Pry the edges of the device to separate the front case away from the rare case.
      • While prying the edges, hold the device with one hand to pull out each case a part.
      • Make sure you use a constant force, and the pushbuttons are pried off completely.
      Ask FixBot
    4. Graco Secure Coverage Parent Unit Power Jack Replacement: step 6, image 1 of 2 Graco Secure Coverage Parent Unit Power Jack Replacement: step 6, image 2 of 2
      • Remove the 7mm Phillips #1 screw from the mother board.
      • Place the screw in a secure place.
      Ask FixBot
    5. Graco Secure Coverage Parent Unit Power Jack Replacement: step 7, image 1 of 2 Graco Secure Coverage Parent Unit Power Jack Replacement: step 7, image 2 of 2
      • Pick up the motherboard carefully to look at the power jack wires.
      • Solder off power jack from the mother board.
      • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack.
      • Replace the power jack.
      Ask FixBot
Author
with
Omar Abdullah
201 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 99
All Time: 759
