Up to 20% off select tools
Graco Secure Coverage LED Nursery Unit Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
90
All Time:
675
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the LED on your Graco Secure Coverage Digital Baby Monitor for nursery unit.
The LED replacement includes the LED and battery replacement.
    1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: step 1, image 1 of 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: step 1, image 2 of 3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: step 1, image 3 of 3
      • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
      Ask FixBot
    2. Graco Secure Coverage LED Nursery Unit Replacement: step 2, image 1 of 2 Graco Secure Coverage LED Nursery Unit Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, pry and remove the battery cover carefully.
      • Remove the batteries using plastic opening tool.
      • Replace the batteries.
      Ask FixBot
    1. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: step 3, image 1 of 2 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: step 3, image 2 of 2
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • Place the screws in a secure place.
      Ask FixBot
    2. Graco Secure Coverage LED Nursery Unit Replacement: step 4, image 1 of 1
      • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
      • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
      • Apply constant force carefully to avoid breaking any other plastic parts from the device.
      Ask FixBot
    3. Graco Secure Coverage LED Nursery Unit Replacement: step 5, image 1 of 2 Graco Secure Coverage LED Nursery Unit Replacement: step 5, image 2 of 2
      • Remove all three 7mm Phillips #1 screws from the mother board.
      • Place the screws in secure place.
      Ask FixBot
    4. Graco Secure Coverage LED Nursery Unit Replacement: step 6, image 1 of 3 Graco Secure Coverage LED Nursery Unit Replacement: step 6, image 2 of 3 Graco Secure Coverage LED Nursery Unit Replacement: step 6, image 3 of 3
      • Flip over the motherboard to look at the LED pins that are connected to it.
      • Solder off the LED pin from the motherboard.
      • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
      • Replace the LED.
      Ask FixBot
Author
with
Bryson Wolff
237 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 90
All Time: 675
