Graco Secure Coverage Nursery Unit Power Jack Replacement
    1. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 1 of 3 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 2 of 3 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: step 1, image 3 of 3
      • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
      Ask FixBot
    2. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 2, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, pry and remove the battery cover carefully.
      • Remove the batteries using plastic opening tool.
      • Replace the batteries.
      Ask FixBot
    1. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: step 3, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: step 3, image 2 of 2
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • Place the screws in a secure place.
      Ask FixBot
    2. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 4, image 1 of 1
      • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
      • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
      • Take your time and apply constant force carefully to avoid breaking any other plastic parts from the device.
      Ask FixBot
    3. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 5, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 5, image 2 of 2
      • Remove all three 7mm Phillips #1 screws from the mother board.
      • Make sure you gently unscrew the screws with moderate force and light pressure to avoid any damages.
      Ask FixBot
    4. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 6, image 1 of 2 Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 6, image 2 of 2
      • Pick up the mother board carefully.
      • Using plastic opening tool, gently pry the power jack plastic part and separate it away from the device case.
      • Apply constant force to avoid breaking the plastic part.
      Ask FixBot
    5. Graco Secure Coverage  Nursery Unit Power Jack Replacement: step 7, image 1 of 1
      • Solder off the wires from the mother board.
      • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack wires.
      • Replace the power jack.
      Ask FixBot
Omar Abdullah
201 Reputation
2 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2015 Member of USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 452
