Up to 20% off select tools
Governor Adjustment
Views: 3.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
34
Past 30 Days:
187
All Time:
3,935
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Governor Adjustment
Introduction
Go to step 1 ↓
Adjusting the governor helps maintain a steady engine speed no matter the terrain and other conditions that could effect the engine workload. While the manufacturer highly recommends against this, it may be necessary to keep your engine running well.
    1. Governor Adjustment, Governor Adjustment: step 1, image 1 of 3 Governor Adjustment, Governor Adjustment: step 1, image 2 of 3 Governor Adjustment, Governor Adjustment: step 1, image 3 of 3
      • Before starting, make sure the engine isn't running and is not hot.
      • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
      Ask FixBot
    2. Governor Adjustment: step 2, image 1 of 1
      • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
      • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
      Ask FixBot
    3. Governor Adjustment: step 3, image 1 of 1
      • Carefully re-hook the spring on the arm it was disconnected from.
      Ask FixBot
Author
with
Aaron Correya
260 Reputation
2 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
84 Guides authored
2 Guide Comments
Wow, I'm very grateful.
Bradley Earnest - Reply Share
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 187
All Time: 3,935
