Up to 20% off select tools
Google Stadia Controller Opening Procedure
Views: 11K
View statistics:
Past 24 Hours:
10
Past 7 Days:
47
Past 30 Days:
218
All Time:
11,019
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 40 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to open your Google Stadia controller for repairs and modding.
Although you don't need special tools to open the Google Stadia controller, the opening process is difficult and requires a lot of force. The case of the controller is held together by super tight plastic clamps which require a tool solid enough to withstand the pressure it takes to pry them open. Take your time and try not to get frustrated during the opening procedure—otherwise you're likely to scratch or otherwise damage your controller.
    1. Google Stadia Controller Opening Procedure, Loosen the screw cover adhesive: step 1, image 1 of 1
      • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Google Stadia Controller Opening Procedure, Insert an opening pick: step 2, image 1 of 2 Google Stadia Controller Opening Procedure, Insert an opening pick: step 2, image 2 of 2
      • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
      Ask FixBot
    3. Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 1 of 3 Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 2 of 3 Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Slide the opening pick along the screw cover to slice the adhesive.
      • Use a pair of tweezers or your fingers to remove the screw cover.
      • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
      Ask FixBot
    4. Google Stadia Controller Opening Procedure, Unfasten the rear case screw: step 4, image 1 of 1
      • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
      Ask FixBot
    5. Google Stadia Controller Opening Procedure, Disassembly information: step 5, image 1 of 2 Google Stadia Controller Opening Procedure, Disassembly information: step 5, image 2 of 2
      • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
      • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
      Ask FixBot
    6. Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 1 of 3 Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 2 of 3 Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
      • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
      • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
      • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
      Ask FixBot
    7. Google Stadia Controller Opening Procedure, Insert an opening pick: step 7, image 1 of 2 Google Stadia Controller Opening Procedure, Insert an opening pick: step 7, image 2 of 2
      • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
      Ask FixBot
    8. Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 1 of 3 Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 2 of 3 Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
      • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
      Ask FixBot
    9. Google Stadia Controller Opening Procedure: step 9, image 1 of 3 Google Stadia Controller Opening Procedure: step 9, image 2 of 3 Google Stadia Controller Opening Procedure: step 9, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
      • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
      Ask FixBot
    10. Google Stadia Controller Opening Procedure: step 10, image 1 of 3 Google Stadia Controller Opening Procedure: step 10, image 2 of 3 Google Stadia Controller Opening Procedure: step 10, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
      • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
      Ask FixBot
    11. Google Stadia Controller Opening Procedure: step 11, image 1 of 2 Google Stadia Controller Opening Procedure: step 11, image 2 of 2
      • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
      • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
      Ask FixBot
    12. Google Stadia Controller Opening Procedure: step 12, image 1 of 3 Google Stadia Controller Opening Procedure: step 12, image 2 of 3 Google Stadia Controller Opening Procedure: step 12, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
      • Repeat the previous procedure at the clamp left to the headphone jack.
      • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
      Ask FixBot
    13. Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 1 of 3 Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 2 of 3 Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 3 of 3
      • Avoid straining the front cover assembly cable during this step.
      • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
      Ask FixBot
6 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
Screwdriver in step 4 should actually be a T9 torx, although T8 also kind of works.
Elbert - Reply Share
Past 24 Hours: 10
Past 7 Days: 47
Past 30 Days: 218
All Time: 11,019
