Google Pixelbook Go Right Charging Port Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
57
All Time:
632
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
In this guide, you will learn how to replace the right charging port on your Google Pixelbook Go to fix charging issues.
Tools
    1. Google Pixelbook Go Right Charging Port Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Right Charging Port Replacement, Back Panel: step 1, image 2 of 2
      • Flip the device so that the back is facing up.
      • Peel the rubber stoppers off the top and bottom of the device.
      Ask FixBot
    2. Google Pixelbook Go Right Charging Port Replacement: step 2, image 1 of 2 Google Pixelbook Go Right Charging Port Replacement: step 2, image 2 of 2
      • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    3. Google Pixelbook Go Right Charging Port Replacement: step 3, image 1 of 3 Google Pixelbook Go Right Charging Port Replacement: step 3, image 2 of 3 Google Pixelbook Go Right Charging Port Replacement: step 3, image 3 of 3
      • Use an iFixit opening tool to pry up the back panel cover.
      • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
      • Remove the single 2 mm screw using a Torx T3 screwdriver.
      • Disconnect the orange cable from the base of the device.
      Ask FixBot
    4. Google Pixelbook Go Right Charging Port Replacement: step 4, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    1. Google Pixelbook Go Right Charging Port Replacement, Right Charging Port: step 5, image 1 of 1
      • Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
      Ask FixBot
    2. Google Pixelbook Go Right Charging Port Replacement: step 6, image 1 of 2 Google Pixelbook Go Right Charging Port Replacement: step 6, image 2 of 2
      • Remove the right charging port by picking it up and lifting it from the computer.
      Ask FixBot
Katie Brennan
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 57
All Time: 632
