Up to 20% off select tools
Google Pixelbook Go Battery Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
47
Past 30 Days:
200
All Time:
6,159
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a faulty battery in your Google Pixelbook Go.
The battery is what stores power in order for the laptop to run. Check out this Troubleshooting page if the device is not charging in case something besides the battery is at fault. If the battery itself is not charging, it will need to be replaced with a new one.
It is recommended to purchase a new battery that comes with a new back cover attached, as it is very easy to damage the battery by peeling it off the cover.
Make sure the Pixelbook is completely powered down before beginning these steps.
    1. Google Pixelbook Go Battery Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Battery Replacement, Back Panel: step 1, image 2 of 2
      • Flip the device so that the back is facing up.
      • Peel the rubber stoppers off the top and bottom of the device.
      Ask FixBot
    2. Google Pixelbook Go Battery Replacement: step 2, image 1 of 2 Google Pixelbook Go Battery Replacement: step 2, image 2 of 2
      • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    3. Google Pixelbook Go Battery Replacement: step 3, image 1 of 3 Google Pixelbook Go Battery Replacement: step 3, image 2 of 3 Google Pixelbook Go Battery Replacement: step 3, image 3 of 3
      • Use an iFixit opening tool to pry up the back panel cover.
      • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
      • Remove the single 2 mm screw using a Torx T3 screwdriver.
      • Disconnect the orange cable from the base of the device.
      Ask FixBot
    4. Google Pixelbook Go Battery Replacement: step 4, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    1. Google Pixelbook Go Battery Replacement, Battery: step 5, image 1 of 1
      • If your replacement battery comes with a new cover already attached, disregard this step.
      • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
      • Carefully remove battery from the base.
      • Align the new battery system with the cover and attach using adhesive or double-sided tape.
      Ask FixBot
2 other people completed this guide.
Author
with
Caroline Gilliard
129 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 47
Past 30 Days: 200
All Time: 6,159
