Google Pixelbook Go Battery Connector Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
42
All Time:
117
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Disconnecting the battery is an essential safety step before performing any repair on the Google Pixelbook Go.
This guide will show you how to safely remove the bottom cover and disconnect the battery cable to prevent accidental short circuits during repairs such as cleaning, SSD upgrades, or internal component replacement.
No prior repair experience is required. Follow each step carefully and avoid using excessive force on the connector.
Tools
    1. Google Pixelbook Go Battery Connector Replacement, Flip the Pixelbook Go over and remove the screws securing the bottom cover.: step 1, image 1 of 1
      • Power off and unplug the device
      • Remove ten Torx T5 screws
      • Lift the bottom cover gently
      Ask FixBot
    2. Google Pixelbook Go Battery Connector Replacement, Find the battery connector near the front edge of the motherboard.: step 2, image 1 of 1
      • Identify the green Torx T2 screw
      • Note the metal clasp securing the connector
      Ask FixBot
    3. Google Pixelbook Go Battery Connector Replacement, Remove the screw and slide the clasp back to lift the cable out.: step 3, image 1 of 1
      • Unscrew the green Torx T2 screw
      • Slide the clasp backward
      • Use a spudger to lift the cable gently
      Ask FixBot
Shreyas vuyyuru
37 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 42
All Time: 117
