Up to 20% off select tools
Google Pixelbook Go Back Panel Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
76
All Time:
1,643
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Google Pixelbook Go Back Panel Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Flip the device so that the back is facing up.
      • Peel the rubber stoppers off the top and bottom of the device.
      Ask FixBot
    2. Google Pixelbook Go Back Panel Replacement: step 2, image 1 of 2 Google Pixelbook Go Back Panel Replacement: step 2, image 2 of 2
      • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
      Ask FixBot
    3. Google Pixelbook Go Back Panel Replacement: step 3, image 1 of 3 Google Pixelbook Go Back Panel Replacement: step 3, image 2 of 3 Google Pixelbook Go Back Panel Replacement: step 3, image 3 of 3
      • Use an iFixit opening tool to pry up the back panel cover.
      • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
      • Remove the single 2 mm screw using a Torx T3 screwdriver.
      • Disconnect the orange cable from the base of the device.
      Ask FixBot
    4. Google Pixelbook Go Back Panel Replacement: step 4, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
Kristen Gismondi
110,396 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 76
All Time: 1,643
